Just started on the vent window overhaul
jkhll8
Kentucky
Keith
1987 R10 2WD shortbox
R10
5.0 TBI
Thanks, I'm sure ill be picking your brain when I get on mine. Are they a tight fit inside the channel, so as to not let rain water inside the door?
Yes very tight. You gotta pry them out and beat them back in lol
jkhll8
Kentucky
Keith
R10
5.0 TBI
I would like to know where you sourced your gaskets. I replaced mine with them being sourced from Precision and they leak air badly. Thanks
I got them from classic parts. They are precision. No leaks yet
jkhll8
Kentucky
Keith
R10
5.0 TBI
I've noticed that the seal kits offered for these are available in either one or two piece styles. Are the seals interchangeable? Does one work better than the other? Or do you need to stay with the style that was originally installed?
You need to put back what it came with. The one piece would probably work but you would have to glue it to the frame and it would be very hard to get it to seal.
jkhll8
Kentucky
Keith
R10
5.0 TBI
Does anyone know of place that these windows can be sent and rebuilt? I can not seem to get the seals in correctly.
What are you having problems with. I may can help. It's very time consuming. Lol
cah2873
East Texas
Chance
Basically, I installed new gaskets from LMC. They leak very badly. On the outside the gasket is buckled up between rivets. I have since put silicone from the window rail to the gasket. Not- on the window itself. It has stopped all of the leaking but it looks bad from outside. If I redo the vent windows again, I am not sure If i will get different results. I am hearing that there are different quality seals from different places and this may be the problem.
jkhll8
Kentucky
Keith
R10
5.0 TBI
That is more than likely the problem is the seals. I ordered LMC seals to start with and didn't like how they fit so I ordered precision seals. They're far superior quality. I know it sucks but I would start over and order precision seals.
cah2873
East Texas
Chance
Where did you purchase them from? Precision Seals?
jkhll8
Kentucky
Keith
R10
5.0 TBI
I think from classic parts. I'll look when I get home.
jkhll8
Kentucky
Keith
R10
5.0 TBI
I got them from classic parts. They are precision. They was $48 with shipping. Well worth it
bluex
Spartanburg SC
C15
Call precision, they have a guy that does it, I believe it runs around $350 for a pair of windows from what I've seen
Sent from my SM-N920V using Tapatalk
RThiel
Worland, WY
Robb
6.0 LQ9
What kind of paint did you use? Rattle can? And maybe semi-gloss?
jkhll8
Kentucky
Keith
R10
5.0 TBI
My buddy painted them not sure what brand paint but it wasn't rattle can. They are semi gloss.
tinbox
