EastAustinSawdust
- Jan 23, 2020
- Austin, TX
- Adam
- C10 Big Ten Bonanza
- 5.7L 350
Alright so I've got a bit of a history with fuel pump problems. I have a Mallory Series 110 fed by a Revolution Electronics relay. The relay turns the pump on for 3 seconds and then off unless the engine is running.
Anywho, the pump shorted out. Again.
The last time this happened (see this thread) I put in a heat shield between the pump and the exhaust. Per feedback from others, I was thinking the exhaust heat might be cooking the electronics in the pump. Well, either the heat shield didn't do it's job, or there's another problem.
I just installed a new, much cheaper pump and everything works fine again. At least if I fry it again I won't be out $150+.
