- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
When I took the starter to the parts store, they tested it 3 times, and it passed 3 times. I was watching them do it, it was zero load test. they just hooked it up to 12v power, and a remote switch. the solenoid would engage, push the gear up, and spin. Hell, I did that at home with jumper cables and a screwdriver. But I thought the store;s machine might have tested it under load. Nope!
Anyway, I found a parts yard that has one for $40, with a money back guarantee. I'm just gonna get it to have piece of mind that it actually is the starter. If it cranks this bitch, Ill order a new one, If not, Ill have to look elsewhere for the solution to the no crank problem.
Yep, I'm sure you've got a bad starter then. You'd think you'd at least hear a click of the solenoid trying to engage the bendix.
And you have turned this engine over right? You know it's not a seized engine?
I guess $40 is worth the labor swapping starters if you had a buddy with a 95 and up 350. Trucks went away from 350's with the new body style but Vans kept the 350 for a few more years. I was going to suggest borrowing a known good starter from someone else truck or van. So yep, $40 for a good used one with warranty is not a bad deal. Just do it. I wanna see that you got this bitch running. I have a feeling it's going to be a good truck.
