- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
and I would just use two 3 port solenoids since they are available and switch the return and send on each. if you wire a 1980 "delay" for the solenoids, you can save them from wearing as fast as pre 1980 ones did. @Bextreme04 I think was the one who shared a diagram of how that worked in our 1980s? I think!I appreciate. Is that for an 87....I note the different compressor. Mine is the little round I think A4 or is it R4. Anyway I didn't know if the wiring went through the computer at all or if it were separate and not part of that harness. Someone said to ground a wire on a relay or something but then it would stay engaged at WOT and if I understand I would have to add a throttle solenoid?
I really wanted this to stay a simple project but now I am swapping fuel system as well. I was going to just use the regulator to cut the pressure back for the carb. But Summit sent me (my mistake or theirs?) the wrong regulator without the bypass. Same number I had written down on my grocery list but my list said 12-803BP and they sent a 12-803....no bypass. So now I am switching out 6 way selector for a 3 way. An electric fuel pump wired through both a relay AND the oil pressure switch. I will cut that pigtail to wire it in properly as well as the relay. I will do this right if it kills me in the process. But I will post all info and all part numbers for reference. I bet it has been done but I be darn if I could find it! Thanks for the picture to at least give me some guidance on the harness.
