JD Miller
- Sep 30, 2024
- Goober Idaho
- JD
- K20 silverado
I have Carb rebuild parts from Cliff Ruggles , But havent had time to finish building a core I have. To frickin busy with many other projects, been sitting for over a year
Is anyone running a JET Performance Rochester Quadrajet.
Have you had good luck or issues?
STAGE 1 - Disassembled, cleaned and inspected to restore factory stock performance. Casting plugs are sealed with epoxy to prevent leak-down. All of the circuits are checked for proper sizing and the calibration is checked for proper jets, primary metering rods and secondary metering rods. Quadrajet Carb is reassembled with new float, choke pull-off and bronze bushed throttle shafts.
Show More
STAGE 2 - All features of Stage 1 carbs plus fully recalibrated idle, off idle, main, accelerator pump and high speed circuits. Provides improved idle quality, instant throttle response and maximum torque and hp.
