US Mag wheels lug nut suggestions
16.5's are still available. The selection is very limited, but you can still buy them.
Chris64
San Diego
Got the wheels on finally - My poor truck needs so much work...I'll make a new thread about that. I'm happy with the wheels except it makes the rest of my truck look really bad.
Also I will probably be switching out the 2" lift for a 4" because it will give me a little more clearance to put uncut front fenders on...but that's a long way away.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
If you haven't pulled the trigger and are considering options, I bought extended tip spline drive lug nuts from these guys and was happy with the them --> LugNutGuys
I second lugnutguys. They actually had the correct acorn-shank lugnuts to put my Spyders on my GMC and less than $30 shipped. Nobody made the correct style metric lugnuts when the wheels were new.
JD Miller
Goober Idaho
JD
K20 silverado
Do you need a "special secret" shaped socket to remove and install them?
Looks good. But We need more better of a side shot(picture) of your rims on your twuck. C'mon man ! :waytogo:
:birgits_tiredcoffee
Looks good, Those are the only rims I like now days since Eagle Alloys 058 are no more. And I cant stand all the new, butt ugly, star wars, techno rims
The truck looks awesome!
sublimeobs
NELA
Knucklehead
@JD Miller I ordered a set of 20 and it came with a thin wall spline drive socket. You can also order the socket separate if that's all you need (I bought a spare to keep in the truck). Note that there are different spline counts, so the lug nuts and socket need to match (six vs. seven, etc).
JD Miller
Goober Idaho
JD
K20 silverado
BigT
Selah, WA
Tim
Scottsdale K20
Damn, I love those wheels... I want a set of matte finish ones bad.
78C10BigTen
pennsylvannia
C10 BIG TEN
So I just got my new wheels which are the US Mag
17x10's
lug nut:
I did a test fit with just the rim before taking them down to get tires (BFG AT 35x12.5x17) added and they fit very similar to what the truck had (Weld 16.5x9.5) Similar offset. A tiny bit wider (5mm) but they only offer 1 size so that made my decision a lot easier.
The problem I had is my lug nuts are old and gross, but also I can't get a socket in the hole to tighten them. Any suggestions? I was thinking maybe the locking style to protect my investment a little.
Something like these - or is this cheap stuff that I'll end up regretting?
I LOVE those wheels!!
78C10BigTen
pennsylvannia
C10 BIG TEN
Nice ta see ya went whites out!!! Good man! Lol
cdoodyny
