JB7, JD7, or JB8
coachdtierney54
US
C30
Sent from my XT1254 using Tapatalk
coachdtierney54
US
C30
These are my front brakes I think I bit off more than I can chew...
CSFJ
looks as though the brake pad is doing a little home machine work on that rotor. A decent manual should walk you through removal and reinstall, the only catch is those things are ungodly heavy.
coachdtierney54
US
C30
So new rotors are needed?
CSFJ
Depends on how long it's been grinding. These old trucks came with a lot of meat on those rotors, but without taking a mic to it to get a proper measurement, you can't say. first step in either situation though, will be to get the hub off.
coachdtierney54
US
C30
coachdtierney54
US
C30
Is this enough? Sorry but I'm very new to this...
CSFJ
A tape isn't going to be accurate enough. most of the service limits are measured in the hundredth, or thousandth of an inch. You'd need to get a micrometer on it to get a real measurement from the thinnest points of the rotor, or take the rotor to where you'd have it turned and let them measure it.
coachdtierney54
US
C30
Gotcha. Thanks for the info. After pricing these, I hope they can be saved. Even rockauto had them for about $100 each...
coachdtierney54
US
C30
What tools do I need to remove it?
CSFJ
you're going to need to get a service manual for your truck. I don't have anything here that covers the c30 front brakes, and most videos on line seem to cover the k30 fronts. I've never played with the dually trucks, so I don't have a definitive answer on what you'll need, I can only guess and make assumptions based on other stuff I've worked on.
chengny
Rotor thickness specs (as new, minimum machinable, and discard) for the various JB classes:
chengny
See the post directly above for the thickness below which they cannot be machined. Also the minimum thickness for machining should be stamped somewhere on the rotor.
chengny
Below is some info on 1985 C30 front brake maintenance. I hope they are legible.
Caliper R & R and brake pad renewal:
Rotor R & R:
venom268
