Is this safe?
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
Was looking online, and found this. Its a square with shackles on the front sides of leaf springs. I had never seen this done before.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
I've seen it done on Willy's jeeps but not on a truck. Not sure if it's safe or not.
firebane
Calgary, AB
Curtis
As long as the shackles are sturdy it won't hurt nothing but it could throw off caster/pinion.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
I was wondering about the axle movement. Having a shackle on the front and the rear of the leaf spring, would let the axle move horizontally.
highdesertrange
kalifornia
mike
k30
depends what's on the rear of those springs. you CAN NOT have shackles on both ends of leaf springs. the fixed mount of leaf springs weather in the front or rear of the spring is what keeps the axle going straight going down the road. highdesertranger
Georgeb
Wisconsin
George
K10 Burb Z71
I have heard of shackles front and rear of springs but only with another method like links to locate the axle. With the shackles on the front and solid mounted in the rear the axle tends to move forward during spring compression its not much but it could have an effect on bump steer depending on the steering setup. Thats my understanding anyway.
MadOgre
NA
NA
NA
NA
NA
Ya definitely not a good idea except for bush use only! You would have front end chatter like no tomorrow!
yeti_87
