Is this a high or low hump
Mcdunn516
Illinois
1985 chevy k10 4x4 column shift... Is this a high or low hump my carpet I ordered is wayy to big...
That's a 2wd cab with the low hump. Someone's done some swappin'.
That looks like a tweaked NP205 shifter too.
Mcdunn516
Illinois
It is an np205 Gear driven, 3/4ton axel swaps as well. So this is a low hump... I think the guy before me did some swaping around. Thanks guys. I sprayed down some raptor bed liner but there is this on spot on the floor the stuff won't stick to so I am going to put some carpet back in it as well. I just ordered the new dash and some new stuff for the interior as well.
Mcdunn516
Illinois
Here's how it sits from the outside. I thought for sure this was a 2wd cab but the guy was adamant it was not swapped
jason81k20
pennsylvania
jason
k20
My 2wd cab I swapped humps
Boone83K10
Boone, NC
Benjamin
hmmm, that is interesting looking. give me that dash pad btw.
Michael
Erie pa
Michael
Scottsdale c10
Where did you get that from I'm doing a swap on a c10
You just have to look for a used one. Online classifieds, junkyard, etc.
Greybeard
Iowa-under a rock
Randy
75 something (maybe ???)
k10 and a 1/3
Two wheel drive and four wheel are very similar for the overall, but the under/in front of seat area is the place that everything is different. I have a two wheel drive cab on my current K model, I tried a number of different humps over the np 205/sm465 to try and get rid of the three inch body lift- all to no avail. Even with new cab mounts I have to use a 1" body lift to get a 1/4" clearance between the t-case and floor. What did I miss? BTW, with no lift kit on it yet I never dropped the back of the t-case.
Tdabney
