Betsy likes this stuff, all the shiny parts and machined surfaces are interesting to anyone.
Rundown on this engine is its a low mile rebuild I got from a guy that owns a machine shop in Seirra Verde south of Tuscon. He acquired it and took it apart to spec everything out, everything spec'd out so he put it in his warehouse so someone could assemble it later.
The crank was micropolished by him when I got it, it had some rust on the counterweights. I should have left it alone but I soaked the crank in CLR, that just made **** worse so I did the electrolosis experiment for the first time and that worked great. All I did about the journals was get some mothers aluminum polish and a sock and polished the **** out of the journals, they actually look more shiny than when I got the crank so I think it will be alright.
Cam bearing tool came off ebay, it was 100 bucks. If you search around the internet about installing cam bearings all advice leads to just having a machine shop do it. If you read any books on engine assembling the author will just tell you to take it to a machine shop. I looked it up in my chilton manual and it just had a paragraph saying to take it to a machine shop
![Party36 :party36: :party36:](/styles/default/xenforo/smilies/party36.gif)
. If you look up "cam bearing install" on youtube there is several video's of guys doing it in their garage and explaining about the oil holes needing to be lined up correctly.
Honestly the job was not all that hard, I just marked bearing with nail polish and marked the block, then just knocked em' in nice and flush. I slid the cam in and everything spins very nicely, there is no scratching on any parts of the cam so I think it will fly. Only issue I have with my work is one of the bearings got chingered somehow, I am going to order more bearings and try the one bearing again. The finish on the mandrel is a little rough, I am going to polish the **** out of it and try again or maybe just look closer at the bearing I installed because it might be okay to run.
At this point you are probably thinking I am an idiot for not taking this thing to the machine shop, there is a reason I am not. Our machinist here is backed up for like the next 6 months, I cant get anything done. The rods and pistons I dropped off for the small block had not been touched in about 4 months when I picked them up. I feel like I can get creative and use good judgment here and do it without the machine shop.
Here is the cam kit I got, nothing to serious since its my daily driver,
http://www.jegs.com/i/Comp-Cams/249/CL01-412-8/10002/-1
I have pretty much everything ready to assemble the bottom end, just need more time. Plan is to do one last really good final cleaning, hose out the shop, change the mineral spirits in my parts washer and get after it. Only hangups at the moment I have is the cam bearing I mentioned and i seem to have a slight ridge at the tops of the cylinder walls, I honed everything and they turned out really nice I am just not sure about the ridge, seeming like I might need to try the dreaded ridge reamer and make yet another high stakes gamble on my engine.
As far as the heads go, I have not even run the casting numbers or done research on what they are. They look good, most likely going to pull them apart, clean them with electricity, check everything out and put them back together. From there im going to run a single plane edelbrock intake, not sure which one yet. Fuel delivery will most likely be the stock throttle body thats on the truck now but I plan on rebuilding it before I install, right now I know the injector on the drivers side is ****** up and spraying way too much fuel.
