Interior redo
eskimomann209
Modesto
Marcus
Sounds good. I have a spot weld cutter, but need to order a new cutter for it, it lost a tooth. Definatly have to put sound dampener and insulation on the firewall while it's out. It doesn't look like there is much room to get a drill in there.
Drill behind the dash you mean?
FireTruck1984
Michigan
Ted
1984 and 1984
What are you going to use for the final covering over the vertical area behind the seat? I think my truck originally had some type of behind-the-seat cover or tray with a fiberboard panel running down the back wall, since there is a line of screw holes a few inches down from the window. However, that tray is long gone.
I've considered carpeting a new piece of fiberboard for a back panel covering, but I'm not sure how will it will turn around inside the cab corners to provide full coverage all the way to the door posts.
Bruce
Back wall carpet is available, LMC and others sell it. It attaches with velcro and is molded to fit all the way to the door post. With sound deadening and whichever insulation you chose it will be very quiet. It’s also a nice clean look and matches the new carpet perfectly
FireTruck1984
Michigan
Ted
1984 and 1984
eskimomann209
Modesto
Marcus
To drill out the spot welds.
The picture showing the rust spot is not what your drilling out. You’re drilling the part where the dash seam, the outer seam and the inner cab seam all meet one another. And it must be drilled through the windshield opening.
eskimomann209
Modesto
Marcus
You’re drilling out the dimples shown here
SDJunkMan
Black Hills of South Dakota
Jeff
So from the outside of the truck? That looks like it would be easier.
Poppy 87
Bloomingdale GA
R10 Silverado
That is a beautiful truck! Mine is white with carmine interior. Now I have something to aspire to when I do my interior. She's still waiting in line for paint job at work, but I'm doing a color change
eskimomann209
Modesto
Marcus
I haven’t bothered to cover the upper part yet. But this is my Thuglife setup. I mainly listen to Country music and Disney score in here. But hey, it works for me. LOL.
seanhatesregister
