Interior parts 92 Yukon
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Good Lord, the late 80s/ early 90s were definitely the dark years of GM interiors!!! Everything we touch breaks on this truck!
Looking for good door panels (specifically the pull handles), passenger front armrest (the part that contains the power window switch) passenger side A pillar trim, and a KNOWN good power mirror switch.
Pretty sure the trim pieces are the same between Yukon/Blazer and trucks.
Thanks!!!
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
Thanks!!!
'92 would be OBS, not square body....
The 2 door Blazer and Jimmy in the OBS trucks were built from 1992-94 in the old style interior, which is similar to the 88-94 pickups. Then in '95 they became 2 door Tahoe and Yukon.
These are getting real scarce around the Houston, Texas area because of age and the interior plastics don't fare well in Southern heat and humidity. It's hard enough to find the later style '95-up OBS trucks with decent interiors down here.
For more information, head over to gmt400.com; we have lots of OBS truck lovers and mechanics over there.
Good luck, it's been a long time since I've seen any decent early OBS interior in a yard. Might have to resort to Ebay.
I'd like to find a set of red door panels from a 1992-94 Blazer/Yukon/Suburban/Crew cab for my '89.
Lol, I had to aquire an entire parts rig just to get those exact door panels. I love the '92-'94 interiors, but dang, parts sure are hard to find.
Oh, and if it helps... the Suburban/Crew cab rear door arm rests/pulls will fit on the front doors, they are only slightly different than the correct front ones.
ruggedly
