Instrument cluster questions on new build
nicofan96
South Carolina
Kevin
c-15
I have a 1979 GMC sierra C-15. It came originally with a straight 6 engine but has been replaced with a 350. Since the engine has been replaced the oil pressure and engine temp gauges do not work. I have heard that the gauges can be replaced with the 350 gauges or the sensors can be replaced with the straight 6 sensors to correct. Any inputs on what direction to go?
75gmck25
Northern Virginia
Bruce
Oil pressure sensor should be the same for all the engines. Pressure is pressure. Temp sensor might be different, but I think they are the same resistance for each year, regardless of engine. However, SBC 350 usually has a 1/2” thread, and some older SBC’s used 3/8”; not sure about 6 cylinder.
^^^^^^ senders have to match the year of tge gauge cluster.
chrisw77
