Inline 6 devac
boot
lenoir nc
hunter
250ci
What do y’all suggest to do to get rid of the vacuum lines and the weird valve cover on my 81 k10 it’s a inline 6 250ci with a 4 speed, I figured change the valve cover and intake and carburetor that’s on it, if anyone has took one of these engines and converted them to a more simple way I’d like to see a picture, this is mine in the picture.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Looks like the California head. Does it have integrated intake and exhaust manifold? I don't think the regular cover fits. I remember searching for an older head to put on my 250.
Turbo4whl
Downingtown, PA
Wayne
All 50 states had the 250's with the integral head/intake manifold.
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
It is an integral head, and the vacuum and piping on top is the Pulse AIR system. I think there is an integral head valve cover without the Pulse AIR system. They would be '75 to '78-ish.
Keep in mind the integral heads are known for cracking, so it may need to go away all together.
Some people try to make them look more 'festive' with color :D
boot
lenoir nc
hunter
250ci
I do appreciate the advice I didn’t know that, I know it’s the only inline 6 I’ve seen in a Chevy with this many lines on it lol, I will rebuild carburetor and continue driving
justhorns
Denver
Lee
I am working on the same engine/project. Soon. Trying to get a few dump loads in before taking it apart. I was looking at a new head (from a 70 Nova, which I now have) and separate intake and exhaust, but this required a catalyst replacement with the new exhaust, or perhaps EFI to feed the cat. The budget just got too big, pushing $3000 for all that. So, I'm going to disassemble the valve cover and other top of motor crap and clean up the mess. So many valves. Will try to clean up and replace hoses that are crap.
The engine runs fine, but it has a tap in the valve train that I'm going to go after at the same time. Will update you after I do the work, but, I think it will be a while..Not sure when I'll get to it.
squaredeal91
Greg bush
1991 SB
What weight of oil are you running?
Keith Seymore
Motor City
Keith Seymore
4.3L
Cut the extra boxes off the top of your original cover at the spot welds. Plug or reuse the holes in the cover, plus plug the holes at the other end of the AIR lines with a pipe plug.
Repaint and reinstall.
K
justhorns
Denver
Lee
If you were asking me, I use Penn grade high zinc oil 10W40 with MOA additive. The tap is very clearly a mechanical bang.. Once each rotation. Something is clearly amiss. I have slow mo video that very clearly lets you hear the tap as a mechanical issue. I'm hoping for a bad pushrod or lifter issue.
squaredeal91
Greg bush
1991 SB
Sounds like good oil. Hope its Something simple. Rocker nuts can let go over time too.
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
Try a quart of ATF in the crankase for the valve train noise. It worked wonders on my 6.2.
jlyon1006
