- Oct 13, 2016
- Northern Virginia
- Bruce
- K25 Camper Special TH350 NP203
I would buy or borrow an infrared thermometer and start checking temps in various locations. Engine side of thermostat housing should get up to 195 or higher. Then check each of the heater hoses to see what temp you get there. Then pull off the hvac housing cover behind the glove compartment and check the heater core temp.
While you have the cover off, check the blend door to see it’s moving full travel and routing all air through the heater core. The cable that determines door travel is easy to adjust at the bracket on top of the plenum.
My truck has the heavy duty heater that came with the A/C option, and it gets so hot that you can’t stand it in the cab unless the heat control slider is at about 20% travel. My truck came from North Dakota, and getting enough heat was never a problem there, regardless of the temp outside. Most Squarebody heaters work very well.
