Im stumpped
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
To install just the trans go kit they said I could do it with little to know problem or pay them 180 in labor and what ever the parts are
It would bebbetter to have them find out first if there is anproblem with the stock VB before throwing performance parts at it that could potentially make an internal problem even worse....prolonging your pain.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Well after putting fluid back in the transmission it shifts fine so I need to fix the pan gasket again and put fluid in again the spring I need to replace will only come with a rebuild kit or a stage 1 shift kit and that's what I need to fix my truck
MrMarty51
Eastern Montana
Martin
Ya ill be looking into that as soon as i can get some guidance from HotRodPc being that he works on these transmissions a lot more then i ever care to...
:pokeowned::emotions133::(
Send Him a PM and let Him know what color Your spring is,he said He may have one laying around.
A little mud{debris} in the bottom of the pan is OK but if the seals are getting to be in bad enough condition then it will require that dreaded rebuild.
BUT,when it is done it will be like a totally different vehicle.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
I agree that's why IMA take the steps I'm going to first cuts I have yet to smog this ****
The small amount of sludge you're getting in the pan is likely from the problem you're having. Everytime this trans is goofing up, it's take more miles off the trans til eventually the trans will need rebuilt. Need to get it corrected ASAP.
You've got nothing to lose by installing a kit at this point. It's either going to work, or it's not. And if the trans needs a rebuild, then you can use the same kit in the new trans or tell the guys to install the kit you just installed. Unless you do a mail order job, then just suck it up, let them install a kit and be done with it so that you don't have to open it up and void any warranty.
All this **** does here, is makes more irritated in my situation that I can't get set up and start building transmissions again. I am so rusty on 700r4's, and that Trans is the money maker now since there are so many out there along with the 4L60-E. A guy could live off doing nothing but 700r4 and 4L60-E's out of his garage. Special tools are needed and they are not cheap. I've improvised on some of them but to hell with that. I hope someday I get set up and get the special tools needed and can start building again. And then I won't be so rusty either.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
I'm waiting on taxes so I can take my truck to the transmission shop and have them check it out
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
W2s are in tomorrow I field taxes and will know what I'll be able to do with my truck
MrMarty51
Eastern Montana
Martin
It just really sucks to be in these predicuments,fuggin pisses me off too.takes money to make money.Having a lot of tools but still need more.crap.
Oh well,I hear transmixer fluid limbers up rust.LOL
I have been helping a friend to work on His 83 1500,He`s as broke as I am,fuggin vehicle needs work and parts,I`m giving Him the labor,He is learning so I feel that at least something is being accomplished but when there is no money for parts,well,it just has to get Him by until money for parts is availeable.really sucks.:wtf2: rant over.
You guys aren't alone. I'm as broke now than I have been in over 20 years.
caliphatman8123
Bakersfield, Ca
Sam
v1500 suburban
tbi 350
I'm beginning to think it a way of life anymore... and you all are right it sucks ass when you need and want to get a project done... I feel y'alls sarrow... tell my son everyday how important school is and he does really well but even I don't know if that's gonna be enough anymore... economy just sucks so job market sucks too...
Sent from my SAMSUNG-SGH-I717 using Xparent Blue Tapatalk 2
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Ya money sucks this truck was not supposed to be a project it was supposed to be straight forward easy fix but its been nothing but up hill
Same here guys. Broke and truck inspection coming the end of the month. :(
Jims86
Patterson,Ca
5.7 TBI
Probably would have been cheaper to pay the back fees on the 88?
DawgmanDew
