Im Jacob and I have transmission problems..
What do you think the problem is?
  • stuck check valve
    Votes: 1 33.3%
  • converter
    Votes: 0 0.0%
  • No mo' 3rd
    Votes: 2 66.7%
  • Other
    Votes: 0 0.0%
  • Total voters
78Scottsdale
Spokane, Washington
Scottsdale C10
Sbc 350
Hello im new and my 78 C10 has been having transmission problems, this is my first chevy but defiantly not my first go around with classic vehicles. So as far as my problems go, the first TH350 took a dump so i swapped it with a low cost ($300) used replacement off craigslist. B&M pan, came with converter, the small amount of fluid in the trans was clean and didnt smell burnt. Since installation my first and second gears put down power, no chatter, the shift from first and second is firm and smooth (possibly a stage 2 shift kit?) and the shift from second to third seems like it takes some time i almost need to push it into gear (give it more throttle). third grabs initially getting on the interstate but as i continue to accelerate my rpms go through the roof and it almost feels like im driving on ice. In the first 4 days for installing the trans 3rd has hooked no problem on the interstate twice and has spun twice. So i take back roads now to save fuel and reduce engine stress. Lastly some mornings it has stalled when accelerating from a dead stop within the first 1-2 miles of driving (lettin truck warm for about 5-10 min). Converter? Check ball? sorry for it being long winded just need to put all my information out there.
*if theres a better place for this to be posted please let me know
Dan Miller
K15SG
Indiana
Daniel
K15
Welcome from Indiana !! I'm not a transmission guy , but this site is full of knowledge, tips and opinions so I'm sure someone will add some useful info that will hopefully help
:welcome:
Preston
Mechanicsville VA
Preston
Welcome to GMSB from Virginia
dvdswan
Port Orchard, WA
Dave
Welcome to the site.
350 w/203
Vacuum modulator maybe?
Do you know how long it sat before you bought it? Maybe some dried seals and as it warms up and the fluid gets thinner the fluid is able to get around the drum seals and the clutch piston grip fades away. It might be worth a try to use Auto Trans Conditioner. They do help many times in a situation where it has sat for a long period of time. If the trans conditioner can soften the seals and that's the problem it should only get better and better with more driving and warming the seals.
The other thing that can happen, is the seals stick to the drum instead of slide with the piston. If they're stuck badly, and that piston does move then it's possible to damage the seals and there is no correcting that without a rebuild.
animal
Lee
c10 silverado
350ish
:welcome:
jjester6000
Illinois
Jack
C1500
The stalling issue sounds more like a carburetor issue more then a trans problem (Just got to war, it up).
As for your your slipping in 3rd, I'd try using some Lucas Stop Slip (It worked wonders on the 330k original TH700r4 in my Suburban). It would probably buy you a lot of time, but to fix it properly, I'd replace the 2-3 clutch pack.
To me Automatic Transmissions are still horrendously complicated; anyone ever heard of the Turbo Encapulator?
Josh Helm
Mooers New York
josh
K1500
5.7 vortec
I second the Lucas oil ... I have had good luck with the product as well ...
1973c10
Don
Welcome :boti:
78Scottsdale
Spokane, Washington
Scottsdale C10
Sbc 350
(Update- got on the freeway this morning and it hooked up just fine, only stalled once leaving my driveway). Ill try the Lucas product, as far as the stalling caused by the carb ill take a look at it but the stalling issue didnt arise until after the transmission swap. But hey fix one thing and another goes wrong wouldnt be surprising. hah thank you for your input
78Scottsdale
Spokane, Washington
Scottsdale C10
Sbc 350
I have noticed the more i drive it the stalling issue has slowly subsided, but the problem with 3rd is still intermittent. Is there anyway to diagnose the seal getting stuck to the drum?
rfeth
