I can attest to this personally. In tracing down my improper wire order and stupidly retarded timing and bad aftermarket cap, I discovered my advance weights were sticking A LOT.
I cleaned them up in place with a wire wheel and brake clean. Used a tiny grease(I know it's supposed to be dry, but it's humid, I didn't perfectly clean it up, and it doesn't see a lot of use, so I used grease to prevent it from doing it again soon.
Here are my other HEI distributors for sbc. I should look at my Buick (small block Buick).
Without adjusting timing, my truck stopped hanging RPMs seemingly randomly. I thought it was carb related, because I had to readjust idle or it would stall randomly. But after cleaning, it really stopped it. I DO need to replace the bushings that the weights pivot on, they are shot. I'm sure that don't help!
