ignition cylinder lock problem
RustyBuckets
Kansas City
Jake
I ended up finding the screw and ive got the steering all assembled. It did not fix the problem :eek:. When i turn the key and makes a little toot sound, like a really quiet horn. Its not a clicking sound. The starter is only about 8 months old. I may roll underneath and check connections to the starter, but i cant think of anything else.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Possibly the neutral safety switch....often overlooked, but they are plastic and fragile. A pain in the arese to replace as they are on top of the steering column by the lower firewall. If your starter is good, battery good, cables are clean and have good contact.....replace the switch, its a $14 part.
RustyBuckets
Kansas City
Jake
IT ended up being the ignition switch on the column was far enough towards the firewall to be activated by the rod. Atleast i know a lot more about my steering column and switches now.
But you've got it fixed now right?
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
Never heard one make a noise before.. Learn something new all the time... Glad you were able to get it fixed...
stuman
Kansas
Stuart
There is an outfit in Wichita Kansas which rebuilds steering columns. I'm sure they can get any part. Look for a local to you steering column rebuilder...I know of one in Dallas Texas too, right there on I20 east.
jbahena95
