chengny
- Feb 22, 2012
- NH
- Jerry
- K3500
As you make these turns you are obviously stroking the steering gear and power steering system. But how about the brakes?
Unless you are making the turns at an extremely slow rate of speed, it would be expected that you are also applying the brakes.
Since your truck is a K30/4WD, would it be safe to say that the brakes are JB8 (hydro-boost).
I am sure you're aware that a hydro-boost braking system is powered by the P/S pump. I also notice that in your OP you have a gut feeling that the P/S system is the root cause of this issue.
So, if you feel that the engine is stalling due to a sudden change in load, and you have JB8 brakes - you might want to look in that direction.
Applying the (hydro) brakes hard - even without turning the steering wheel - will often put a big enough load on the P/S pump that it screams. That load is ultimately transferred to the engine via the drive belt.
Just something to consider.
