79dentside
- Nov 20, 2019
- Kansas
- Brandon
- GMC Sierra Classic
The trucks brakes have been out, so I was going to do some new lines. Now I’m wondering what I was thinking. Have any of you done hardlines in your trucks? I kept rounding off the nuts as I was trying to disassemble things, so I am in a situation of having to replace a couple of the lines as I was planning to do anyways, but still.
I am worried about the passenger side line that runs to the rears. Since I damaged the line, I cut it out, but how does a person finagle a new line in that’s pre-bent?
I drew a terrible diagram from the booster down. The 2 pink highlighted segments are the ones I need to replace.
I’m getting a little flustered over my mistake, I should have NOT messed with the steel lines. I have the line going to the rear and the line going to the front right to replace. I wasn’t sure if it was my line or the splitter that was bad so I just went at it with seized lines and now I regret it.
Any advice on a good set of lines and a good game plan of snaking it in with a 90 degree bend?
thanks!
thanks!
