I Keep Smoking My Alternator Belts... Why?
350runner
tx
Ceasar
Check to make sure no positive wires have burnt on the exhaust or anywhere else.
That stuff is all good and clear, I repaired and rerouted the harness when I did the engine swap.
How about pully width? What pulley did you use off the Wee O Five again? I know I read that somewhere in the thread. IIRC, my big block has the wide serpentine type Alt belt, then a standard V belt to the PS pump.
The original '84 305 had regular 'ol v-belts. I'm still using that alternator and pulley. The 454 crank pulley evidently is much larger than the original small block pulley. I guess I didn't think much of that when stuff was getting swapped around.
seanhatesregister
