I hate the power window and door lock switches
YakkoWarner
Central Texas
Wolf
R2500 Suburban
You can get a ratcheting crimper, they are considered to be better and can provide the proper way to do it. the single step ones you get at the store are basically useless to the question of "proper" crimping. While I dont hesitate to use them , I want to get the proper tool and see how its done. You can definitel tell/feel the difference in the finished result, i compare wires done factory in bladed connectors vs a crimp blade or ring terminals since they are usually the same size as the factory kind you can compare a similar wire gauge/insulation combo and similar end fitting and the factory one is much more robust. Because of this i limit my crimps at this time to custom stuff im not worried about failure or i have other means of securing reliably.
From here on I just explain what is a good example i dont mind crimping the less reliable way with cheap crimpers
For example , I ran a spade-female off a random ass tab in the dome light of my f150 to the front to run a floor lamp (obs fords had no option for floor lighting, same as later GMT800 trucks.)to a wire which I tucked behind the trim that runs along the windows around the top of the windows to the pillar, then to the place where the dash bottom is, then just followed that along to where my lamp is. The wire isnt at risk of pulling the connector because its secured tightly in that trim and it makes several 90s on way to its destination, didint have a harness to tuck it in for most of its run but i didnt conduit it with the wires under dash that i followed just to retain it and protect a bit
the lamp is a squarebody harness for a ashtray/floor lamp from the 70s, lol. I didnt feed power to the ash tray lamp yet because the way squarebody does it feeds them separate because the doors feed power under different circumstances than the ashtray. Plus i dont have a way to hold the 194 bulb in the ford, i may just change it to be power feed to an LED strip or something to provide less intense but wider spread light or run it to behind the seat to light up that area when doors open or switch is turned.
I always prefer to use proper tools when available - I have not seen one of these "ratchet" crimping tools - I assume it uses some sort of arcane laws of physics to increase the mechanical advantage? I'm also going to assume its not something one can get at the local Harbor Freight or Autozone?
im not even sure if these are quality or not but heres a quick demo of concept at least
as it pertains to vehicles made by gm, but since a lot of manufacturers used delphi system not just gm, this is likely helpful for a lot of people.
CheemsK1500
K1500
I have experimented a lot with different crimping techniques. The best that I have found is to use ratcheting crimpers with heat shrink style butt connectors. The plastic melts onto the wire insulation and "grips" it, this makes it harder for vibration and movement to cause a wire to back out. I also sometimes fold the wire onto itself (not too much, or it could tear) to fit tighter in the butt connector.
marine shrink tubing has adhesive that helps seal and support too
91burb2500
Plantation, FL
Joey
Suburban R2500
Once you use a ratcheting crimper, it’s hard to go back. They give consistent results time after time, always a solid connection. I come from the marine world where most wiring is custom made and utilizes crimps extensively.
The heat shrink with adhesive is also good practice even in automotive, it supports the wire jacket and seals the connection. I’ve noticed for a while now that the GM repair plugs for harnesses all come with heat shrink/adhesive lined connectors, makes sense.
I replaced all the switches in my Suburban with the Dorman ones about two years ago, so far so good. I had to replace the connector on the master switch on the drivers door as the cables were falling out of the original one. GM makes a replacement and the wires came out on the back rather than the bottom so it forces the plug into the switch pins with the force of the door pushing against the door card.
CheemsK1500
K1500
The ratcheting crimper is a game changer. I remember the absolute misery of trying to crush butt connectors with lineman pliers or channellocks. Soldering is also a tedious affair in tight spots and isn’t really super protected against vibration damage. My ratcheting crimper (I forgot the brand name) is the best $30 I have ever spent.
59840Surfer
Montana
Joe
I worked in a cryogenics research facility (SeaLab) and they would not use the crimpers that put the pointed dent in the crush zone.
They had to run to US Navy standards that forbade them because they tend to over-crush the individual wire strands, and they are made of copper and they get cut or broken soon after.
Some crimpers only put those half-moon crimps on each side so the wires never got a singular hard point of crush.
Then I got the special crimper that puts a kinda-square crush on both sides and is also NASA approved.
LINK HERE
I still have the Panduit®* gun (for what is commonly called a Zip-Tie) that not only pulls the leg to the optimum tension, but then cuts the tag end off at the lock-end - flush.
* - invented the Panduit®, cable tie straps for NASA.
As an Amazon Associate we earn from qualifying purchases.
91burb2500
Plantation, FL
Joey
Suburban R2500
LINK HERE
I use the exact same crimp tool, they have a stripper that they sell together with the crimper that has stripped thousands of wires for me and still works perfect. Flush cutters for the tie wraps, nobody likes to get sliced from a tie wrap tag end sticking out.
PhotonFanatic
Arlen, TX
Wilhelm
beckya7383
