Juan Cano
- Jun 7, 2021
- Warwick, RI
- Juan
- C10
- 350 Goodwrench Crate
Long story it all started with trying to fix the dome light which led to a new headlights switch (didn't fix anything) which led to removing the dash because it didn't fit well (had to get more clips). Now I am putting it back together, put the dash in, trying to wrangle the freakin gauge bezel in, and suddenly, truck is dead.
Dead.
Lights turn on and battery is ok, but truck just clicks, no lights on dash. Someone suggested checking the Neutral Safety Switch cable coming loose but it's not loose, it's on firmly. Seems like a Neutral Switch issue but the switch seems fine plus it's so far back there's no way I could've hit it. Wife drove the truck yesterday and no issues. Then I worked on putting the dash/gauges back in. So something happened there.
What else besides the Neutral Switch could cause this?
I looked under the dash behind the column and all I found was this plug that is not hooked to anything. But it doesn't mean it was hooked to anything to start with right? These old trucks. I couldn't find where it goes.
1986 c10 Silverado, in C+ shape.
Dead.
