I AM STUMPED!
BigDaddy72
Bentonville Arkansas
Travis
C30 Chassis Cab
I don't know what these are, but I think a lesson has been learned here, take pictures before tearing things down so one has a reference when putting things back together. My initial thought was adjustable rear leaf spring shackles, but there would have to be four of them.
I build street rods for a living and we always take pictures but when you are completely disassembling everything and are fabbing custom one off parts some times you just miss a piece or in the picture process.
Especially when the project sits apart for 2 years like this one.
The lesson is don’t take it apart until you are ready to go back together even when life throws you a curve ball or 2. Lol!!
This is the most recent Street rod I built every square inch of.
You guys may like this, place I even did the custom interior.
BigDaddy72
Travis
C30 Chassis Cab
Part #2 looks like the rear spring hanger braces. My K30 has ones on the front and rear, not sure about the 2WD. It would be part #11 or the one with no part number to the right of #14.
I sure appreciate the help and the brake down but unfortunately (unless I’m just not seeing it) it’s still a mystery...
ajd89
Central Michigan
andrew
Think that goes on the bottom of the frame. Helps support the leaf spring hanger. I believe the shackel bolt goes though it then riveted to the frame.
Termite_Delight
Lanark Ontario Canada
K2500 K2500
350 L33
Glass or steel?
BigDaddy72
Travis
C30 Chassis Cab
Glass or steel?
All steel 33 ford. all factory original parts.
I built a 388 sbc with afr heads and howards hyd roller cam.
For it
All forged scar 4340 rotating assembly. Weisco forged pistons.
It’s a custom built hot shoe Hot Rods chassis.
Ford 9” ladder bar 3.73 posi wilwood disc brakes. Strange center section.
Coil over a arm front end with billet specialties wheels 20’s in the rear 18’s up front.
BigDaddy72
Travis
C30 Chassis Cab
Like this?
Only problem I see is there is only one rivet hole and it doesn’t quite line up.
I mean it looks good and I sure like the idea of putting it there and using it for that purpose.
eskimomann209
Modesto
Marcus
Like this?
I think that one goes on the front bracket. Looks like you have it on the rear one. But yeah, That’s the right idea.
I dunno about the other flat bar.
BigDaddy72
Travis
C30 Chassis Cab
10-4 there good buddy I’ll check when I get back to the shop tomorrow.
I sure do appreciate your help friend!
Btw you are correct sir I do have it on the back spring hanger.
ajd89
Central Michigan
andrew
Mine has 2 rivits. on back of the back spring hanger.
ajd89
Central Michigan
andrew
The 3 hole thing would those line up with the 3 holes in the bumper where the balls go? Like some kind of home made plate to strengthen the bumper? Idk.
dvdswan
Port Orchard, WA
Dave
75Monza
Colville, Washington
K30, K20, K20
:eek: salted roads!
eskimomann209
Modesto
Marcus
Mine had the braces on the front and back hanger.
I mentioned it probably fits the front because it’s a little away from the frame in the spot he has it now. Lotta variations around the trucks . For a second I even thought it was a front bump stop from a 4x 4 but he says his trucks a C30.
Who knows. Educated guesses are all we have. I’m sure the parts could even be 1ton specific so us 1/2 and 3/4 ton guys aren’t much help.
Doug Hampton
