Huck's daily - 2005 Z71 crewcab
Try welding a washer to the stud first, then weld a nut on.
Then use a an air hammer to peen the nut you just welded on, then try to remove it
So one bolt is broken off just shy of being flush, the other broke off probably 3/8" down in the hole. So I was trying to build weld up on the bolt, then welded a washer to that, then the nut to the washer. It just broke the weld off of the bolt every time. And I had already drilled the bolt a bit so I had fresh, clean bolt to weld to. I'm gonna give it another shot today if the machine shop won't touch it and I'll turn up the heat some more. Had not thought about peening it, I'll also try that
WFO
Texas Panhandle
That's a good thought. I'm gonna run down to the machine shop in town and see if they'd tackle it and for how much. If they won't bother, then I'll pick some of that Freeze-Off up (if the parts store has some) and give it a shot.
I'd imagine that machine shop can get'er done.
In the meantime last night, I got the other head disassembled (I'd already disassembled the head I was trying to get the bolts out of), inspected and lapped the valves and put it in our parts washer to clean all the oil out of the intake ports
One thing I found was the intake valves and seats look like they've had a valve job done in the recent past. The guy didn't mention a top end rebuild and the valve stem seals looked gunky but these look awful clean for 187k miles
Hard to tell on the exhaust valves but the seats looked better than I'd expect so who knows
So I just did a light lap on all of them, mainly just to clean up the exhaust valves
The oil gunk was like an 1/8" thick in all the intake ports :oops: so they got thrown in the parts washer. A catch can was ordered last night lol
Not perfect but good enough for the girls we date. It'll get one last scrub with some brake clean today before reassembly
Dropped the head off at the machine shop, dude was super nice. He told me normally it's $30 per broken bolt but since I'd F'd with them, it may go up to $60/bolt depending on how bad they fight him. Said sure, no problem. Headed back to work, was in the Zaxby's drive through and he calls saying they're done. That was 11 min later lol.
So I went to work, ate lunch, waited for the incoming storm to pass and went to pick them up. He said they didn't fight much at all, so $70 out the door with tax, tag and title. From now on, I'm not messing with any stud if it's broken off down in the hole, it'll just go to him lol
That's great! Wonder what he did to get them out.
Same thing I did, just successfully lol. He told me "Not that I wanna take business away from me but if you do the welding trick and peen it with a hammer while working it back and forth, it'll usually come out". I pointed at my beard and told him "I tried everything my patience would allow me to, I'll bring them all to you from now on" and he laughed hard :lol:
ANTvenom
