shiftpro
- Aug 31, 2012
- BC Canada
- shiftpro
- 1500, 2500, 3500
- 350, 383, 454, 496!
Depending on the machine, open the door where the spool and feed mechanism is located. Most welders have instructions inside this door that shows basic heat and feed speed for material thickness. They often have a diagram to switch the cables. The ground cable and 'hot' lead need to be reversed.OK that is my problem. I use flux core, because I only use it for body work. Maybe once in a while something a little heavier. I have a Hobart welder, and I always get splatter. I am looking into getting a bottle of gas. I was told I would get a better all around weld with it. How do you change the polarity?
Youtube search your model of machine and/or reverse polarity settings for mig... something like that if you need help.
You will get a cleaner weld using gas, and don't reverse polarity in this case. But it's very difficult to weld outdoors with gas because even a bird fart will blow away the gas shield and introduce oxygen to the weld and that will make you very sad...
