How to pick the right jack+stands
I just got a set of 6ton pro-lift stands from Amazon for cheap, and I'm actually surprised at the quality for $40.
They're way better than the crappy Craftsman stands I've been using for years. Much heavier, better welds, and they have pins.
Link?
thecantaloupeman
US
Dawson
C20 Silverado Camper Special
They do look pretty good so I might go with those. Now in terms of an actual floor jack, will a small 2 ton JEGS one work good enough to lift my truck? I'm mostly worried about the 13" lift range. Is that enough to lift the vehicle enough to get jack stands underneath?
I measured from the pavement to the bottom of my axle, and then added about 2" to figure out the minimum lift I needed to change a tire. If I need more than that lift I can put one or two 2x10s under the jack to get some additional height. You can also get higher lift by jacking up under the axle pumpkin instead of the axle tube.
The jack set I bought is from Home Depot, and it was sold as an SUV/truck jack and stands. The end of the arm sticks up several inches to give higher lift, and the saddle can be screwed up and down to increase the height a little more. It can lift up to 21". Just remember that its not intended to be a car jack, since the minimum clearance is 7 /12" to fit it under the vehicle. https://www.homedepot.com/p/Husky-3...PIPHorizontal1_rr-_-204079069-_-206696699-_-N
KilgoreTrout
Pennsylvania
Dylan
350ci
I'd get one that goes higher than 13.
I use a 1.5 ton rapid pump jack from harbor freight. It's a low profile car jack (that's what I originally needed it for) and it goes up to 13-7/8". I wish it went a couple of inches higher for 4x4 work. It does the job, but just barely enough.
KilgoreTrout
Pennsylvania
Dylan
350ci
The 3ton HF rapid pump heavy duty low profile jack goes up to 19-5/8" and it's only like $95.
It's a lot heavier because it's beefier (and all steel.....mine is aluminum), but if I had to do it again, I'd probably get that one.
Preston
Mechanicsville VA
Preston
How about a 20,500 lb RV, I have been using some 6x6’s but I put the wheels back on it to raise it up high enough to get under the frame rails there are “Tees” and junctions all over the front of this RV for the brake lines as well as 1 1/2” vacuum hoses going to the power boosters, looks like I have a lot more to check out. Just want to feel safe crawling around under this thing
03z71lt
