How to measure a lift?
Truck82
Alderton
Christopher
I’m buying a set of axles with unknown lift springs and was wondering what’s the best way to measure how much lift it has without it being installed. I don’t NEED to know this I’m just curious what it is before I put it on something. Any help is appreciated.
Thanks in advance!
nvrenuf
Mobile, Al.
The springs are NOT on a truck? It's easy on the truck but I don't know a measurement if they're loose.
legopnuematic
Licensed Junk Dealer
MO
Spencer
If you can find some kind of identification on them would be, as mentioned the easiest and best result.
You may be able to measure the free arch of them and number of leafs, etc, and troll through the common offerings, tough country, rough county, skyjacker, etc and might be able to match it up. May not tell you 100% what you have but get a basic ball park idea.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
How many leafs are on the front axle
Truck82
Alderton
Christopher
I’m not sure as I don’t have them at my house and can’t check until tomorrow. Everything I’m seeing and hearing is you can’t check until it’s on the truck. Not a big deal just thought I’d try. Thanks for the reply’s @everyone
Truck82
Alderton
Christopher
I don’t see any identification on them unfortunately
Truck82
Alderton
Christopher
47” 3 stacked leafs. 4.5” shackle plates (center of hold to center of hole)
Vbb199
Salisbury NC
Vince
I believe thats about a 2" lift, maybe 4
Does the front leafs have a little arch
Truck82
Alderton
Christopher
Yes the leafs have a bit of arch
willaustinss
