how to delete auto door locks
BADASSTRAPPER
ASHLAND OREGON
SHERMAN
SUBURBAN
I have an 1987 suburban, it has a feature that when the ignition key is turned on the power door locks lock and when the key gets turned off they unlock ! I would like to delete the feature. Anyone know this is done??
gmbellew
Kansas city
glen
suburban 1500
that is a feature of your remote entry system. you will need to follow the manufacturer directions.
BADASSTRAPPER
ASHLAND OREGON
SHERMAN
SUBURBAN
This is a factory feature on a 1987 ! there should be just a wire to disconnect , just dont know which one ! Anybody ??
Originalthor
Saskatoon Saskatchewan
Scott
Suburban
On the right side of the steering column just above the gas and brake pedal is the relay for the door locks. Trace those wires and see if anything is tapped into them.
Yep, there's an old alarm system or keyless entry system that is locking the doors automatically. Find the box and remove the power lock output. Or you can remove the whole thing, but then you will likely have to patch wires back together for the starter circuit.
R Carnella
Long island
Rich
Suburban V2500
Sounds like one of those old viper alarms from back in the day...
seanhatesregister
