How to achieve tighter steering?
YellowTruck
North Carolina
Dylan
v30
87 Chevy v30 with 6inch lift, Dana 60 rear end, and 38.5” boggers. Ever since I got the thing it’s had extremely loose steering. 45° of play either direction. Replaced the steering box a while back but it really didn’t help. What are some things I should try replacing to help tighten up the steering and make for a more enjoyable driving experience?
Shorty81
Baby Boomer
North West ohio
Darren
Well.. From past experiences, the 6" lift and 38.5 boggers are not conducive to tight steering. Aftermarket steering boxes are garbage. Hit or miss. Do you have the correct steering arm to your lift??
nvrenuf
Mobile, Al.
I agree, a lot will depend on what steering correction pieces you currently have.
A lot will also depend on if there is loose/worn components as well.
While a helper rocks the steering wheel back and forth, look underneath for slop in anything and everything.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Make sure the leafs are tight and their bushings aren't broke down also, that'll cause the whole axle and leafs to move side to side
Kurnacopia
Tucson, AZ
Scottsdale
Look at the Steering shaft and see how worn the rag joint is. This design allows a lot of slop no matter if new or not. Check out this Jeep steering shaft hack. It replaces the Chevy shaft with a Jeeps shaft which has no rag joint. I am doing this now to my 78 Cheyenne 4x4.
77 K20
Montana
K20 5" lift
HT383 fuel injected
wlwarnke
Helotes, TX
William
After checking/fixing and issues, then crossover steering. I also made a receiver hitch for the front of my K5. It’s handy for all receiver hitch type purposes (cargo carrier, recovery point, backing trailers into tight spots), but it also ties the two frame rails together very well to prevent flexing.
I only have 35s but my 16 year old daughter and wife have no issues driving down the highway.
SquareRoot
:pics-stfu:
1990suburban2500
british columbia
steve
suburban 2500
I dont love the idea of grinding anything on my steering assembly, im wondering if a different bolt with a longer shoulder might work. I know Borgson makes replacement shafts but their like $350 or something insane. How much better is the cross over steering, is it work the money? Ive got a V2500 on 33's, super mellow and i like it that way, do lots of highway miles and the play in the steering wheel is exhausting and dangerous.
Kurnacopia
Tucson, AZ
Scottsdale
I have the frame support welded on but will be adding this as well. It uses torsion across the mid cross member for support instead of relying on just frame stiffness:
Look at the following:
Rag Joint
Frame cracks
Bad steering gear or needs adjusting
replace rag type with jeep steering type - google that
get rid of non radial tires :)
wlwarnke
Helotes, TX
William
You must have like 2” min lift to be able to run crossover.
If you’re running stock (flat springs) then you also shouldn’t really have severe bump steer.
Crossover isn’t going to fix any looseness in your steering.
My buddy told me he checked and inspected everything but still had loose steering.
I helped investigate, we found a cracked frame and worn column bearings.
If you steering is sloppy. Check it all from rooter to tooter. Something is bad.
I now have Crossover and Hydro Assist and absolutely love it.
wlwarnke
Helotes, TX
William
Totally forgot about pics. Then remembered pics but not what to take them of and couldn’t find this thread. I’m old, gimme a break.
joker04
