ryan_289
- Apr 17, 2017
- Arkansas
- RYAN
- C20 Royal Sierra
Ive been working on the temp sending units and such on my 78 C20. The coolant ive drained out has been pretty brown and dirty. Before I put a thermostat back in I thought it would be a good idea to run water through the block and drain it out several times until I get cleaner water. When I get finished I figure I will be pretty close to straight water in the block. How much will that be so that I can put the correct amount of anitifreeze in the radiator to get a 50/50 mix?
