How hard to go backwards?
YakkoWarner
Central Texas
Wolf
R2500 Suburban
My 1989 Suburban has the high-low beam switch mounted at the base of the column with the actuator rod going up to the turn signal/wiper/cruise multifunction lever. The rod does not seem to be connected to anything at the upper end anymore, I suspect the plastic has probably broken. The switch works just fine if you reach up there with your finger and press it, so I know there is no wiring failure.
I am wondering how difficult it would be to go back to a floor mounted button for the high-low beam function because frankly the thought of disassembling the column gives me nightmares. Has anyone does this?
Edelbrock
Senior Member
Earth
Grumba
K5 Blazer
I would assume that a floor mounted switch would be easy to install. Probably get one on Amazon cheap enough. The trick would be accessing the wires in the steering column. Maybe there is a wiring diagram on this site somewhere, so that you could take the wires from under the dash or something.
Strick
Dunn, NC
Harold
C20 Crew
The floor switch will plug directly into the column harness. You can make you a jumper lead to floor or dash mount the switch.
Strick
Dunn, NC
Harold
C20 Crew
Industry should quit with column dimmers because idiots keep getting their feet stuck in the steering wheel! I know, should've posted in the funny stuff...
HS
Dizzol
