YakkoWarner
- May 29, 2024
- Central Texas
- Wolf
- R2500 Suburban
My 1989 Suburban has the high-low beam switch mounted at the base of the column with the actuator rod going up to the turn signal/wiper/cruise multifunction lever. The rod does not seem to be connected to anything at the upper end anymore, I suspect the plastic has probably broken. The switch works just fine if you reach up there with your finger and press it, so I know there is no wiring failure.
I am wondering how difficult it would be to go back to a floor mounted button for the high-low beam function because frankly the thought of disassembling the column gives me nightmares. Has anyone does this?
