HOW GEAR OIL?
JD1973
AZ
Jonathan
Chevy 1/2 stepside
How many quarts of gear oil is needed to fill a 12bolt rear end with the B&M cover on it?
Dleslie212
Phoenix
Dustin
5.7L 350
Ok. You just exist to argue with people, don't you? That's pretty much I ever see you doing on here, is replying to threads to argue about the dumbest stuff. Do you not have anything better to do?
There is no way a 12 bolt chevy,took a gallon and a half on a refill. I wanted to make sure the O.P got accurate information.
Dleslie212
Phoenix
Dustin
5.7L 350
The B&M cover is designed to hold way more fluid than stock. It butt's out further and the fill port is much higher up
O.P. I'm going to say just a shade under 3 quarts, please let us know. Thanks
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Not wanting to stir the pot, but just clear things up.
Pretty straightforward to check into…
Says the b&m cover adds 1/2 quart capacity.
Jegs kit with the b&m cover comes with two quarts of gear oil, it looks like.
Meant to hit like accidentally hit quote.
What are the chances you put in 3 bottles of gear lube. Now if you were thinking the bottles were 1/2 gallon I could understand you thinking you put in a gallon and a half. The bottles are quarts. Also what are the chances you filled it until oil ran out the hole in the rearend cover? You are only supposed to fill it until it runs out the axle housing fill port,then stop filling and replace both fill plugs. If you didn't do that it will allow you to grossly overfill it.
Carb'ed Vortec 350
If you call having years of knowledge, and then sharing said knowledge with forum members, as being argumentative, then yep he argues with everyone. I personally enjoy him sharing his knowledge. @Ricko1966 Please keep sharing your knowledge.
legopnuematic
Licensed Junk Dealer
MO
Spencer
The fill plug on those covers are not to be used as a level plug. The original fill/level plug is to be removed, and filled until fluid comes out of the hole in the housing, not the cover.
Instructions from B&M
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I need to change the gear oil in the 84's 10 bolt. Now that I now how to fill it, what type of gear oil should I use? Isn't it 80w-90?
outrageous
