How do I know if I have HEI, and if I don't have it, should I upgrade
75Monza
Colville, Washington
K30, K20, K20
By the way, in his earlier thread, the picture shows, I believe, a points dizzy.
Not sure if you put the wrong picture up, but that there is your basic GM HEI, fat cap with the coil on top. Aftermarket wires without the knobs on top to fit in the stock plastic hold down that is missing also.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
[emoji38]:beatdeadhorse5:
It's beyond beating, it's a sun baked skeleton, that's being torched,
And I love the smell of cooked Bones
Sent from my SM-G965U using Tapatalk
73c20jim
Tombstone, AZ
OK I goofed. HEI.
:emotions33::patriot:
Don't :biggun:
Absolutely.:beatdeadhorse5:
Big Chip
Michigan
Kevin
C35
I believe he should do an experiment. If the shock he gets feels like 18,000 volts it's probably points. If it feels more like 40,000 volts he definitely has HEI.
Vbb199
Salisbury NC
Vince
IF iTs 220V fRoM tHe DrYeR hOw MaNy VoLtS iS iT
Vbb199
Salisbury NC
Vince
Depends on if your pissing on it or not. :shocked:
I can speak from experience, while it's not 220 (I don't think)
Don't pee on the electric fence
ExtraZ
