Jwernatl
- Oct 5, 2020
- Senoia, GA
- John
- V10
- 5.7ltr
Hey all - I installed a new HOLLEY tbi on my 878 v10.
I need to set the base idle. However reading from the drivability manual: STEP # 3 tells me to 'ground the aldl connector' -
and in STEP # 4, it says 'Remove ground from Diagnostic Terminal'
MINIMUM IDLE SPEED ADJUSTMENT - TBI 220
This adjustment should be performed, only when the throttle body assembly has been replaced. Engine should be at normal operating temperature, before making adjustment.
Adjust
1. Remove air cleaner, adapter, and gaskets. Discard gaskets.
2. Plug any vacuum line ports, as required.
3. With IAC valve connected, ground diagnostic terminal (ALDL connector).
4. Turn on ignition, do not start engine. Wait at least 30 seconds, (this allows IAC valve pintle to extend and seat in throttle body).
5. With ignition "ON”, disconnect IAC valve electrical connector.
6. Remove ground from Diagnostic Terminal and start engine.
7. Remove plug by first piercing it with awl, then, applying leverage (Figure 4-27).
8. Adjust idle stop screw, to obtain 700 rpm + 25 rpm 500-550 rpm in drive with automatic trans. and 600-650 rpm in neutral with manual trans. for 4.3L & V8 engines.
9. Turn ignition "OFF”, and reconnect IAC valve electrical connector.
10. Unplug any plugged vacuum line ports and install air cleaner, adapter, and new gaskets.
Thanks everyone - IM sure it's something simple- but cant figure for the life me - I believe Im over thinking it.
Adjust
