MrMarty51
- Oct 25, 2012
- Eastern Montana
- Martin
- K20
In the morning I will be going to remove the wire harness from a 87 Suburban and I do not know how to disconnect the wire harness from the firewall side of the fuse panel,if it is like the 90 version it seemed that it was glued together and I finally had to just clip the wires at the fire wall then go inside and clip the wiring in there too.Maby these 87s are just held together with a couple of screws,I dont know.
This 87 I would like to keep the harnesses intact as much as possible.
I do not like cutting wires,it seems very taboo to Me,I would like to have the complete uncut harnesses so when I get ready to convert an older pickup/truck to TBI I would like to just be able to remove the old harness and install the new along with the electro speedo.
I`ll be going to get this done at about 8 AM and I have until noon to get this all out from the dash and engine bay.
I do have the computer box out and the harness from it fed out through the firewall.
Now it is just a matter of disconnecting the harness from the box so I can keep it all nice and neat.
Thank You in advance for any responses.
