Horn does not work
Andrew Koetz
St. Paul, MN
Andrew
K20 Chevy Suburban
5.7 350 V8 208 T-Case; 10 bolt front 14 bolt semi rear
I bought an 84 K20 Chevy Suburban last year. I discovered after changing out the steering column the horn does not work; (side note; I am rebuilding the original column over winter as I have time). I have it fully apart and just need time to reassemble it. Where is the horn relay under the dash of these trucks (or is it under the hood on the firewall)????? I also have to replace the electric motors in my doors for the electric windows; any suggestions for manufacturers as 99% of them are made in China????
Andrew Koetz
St. Paul, MN
Andrew
K20 Chevy Suburban
Not yet. I need to do one. The current column in the truck is from a 90 Suburban, as the original column had all thee main 4 bolts "very, very, very loose"; dangerous to drive. I located a burb a guy was parting out over in Sconny and went there to pull the column out of that burb & it was the same column I had in my truck. I am in the process of rebuilding the original column over winter and when I have time in teh spring and summer when I am not working.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Mines a little older (1980) but here is where my horn relay is.
Dano500
Houston, TX
Have you done a continuity check on the column?
Hello,
Sorry for my ignorance, but my horn isn't working either and need to find the problem with my 84'. How do you perform a continuity check?
Thanks in advance,
-Dan
m4chine
