hood alignment
Holl
Rich
suburban
how do you align the hood on a 84 suburban? the hood is higher than the fenders and cowl at the rear of the hood.
Holl
Rich
suburban
Thanks, But I have these type of hinges...Mine is made of 84/87 parts..... I have a 84 shop manual and couldnt find alignment for the hood....
Turbo4whl
Downingtown, PA
Wayne
To start, lube the the hinge pivots, all 10 of them.
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
Is the rear of the hood possibly resting on the air cleaner? I had this issue for a bit before I realized hood was doing that, changed to a 1" shorter filter element and problem solved. JM2C:party52:
Holl
Rich
suburban
i dont think its resting on the air cleaner...its stock, the truck has a 1" body lift and there isnt any rub marks on the hood insulation.
I will lube everything
FireTruck1984
Michigan
1984 and 1984
Loosen and adjust the rear hinge bolts
Turbo4whl
Downingtown, PA
Wayne
Good. After you do that and open and close the hood a few times, then go to the rear of the hood (hood closed) by the hinge and push down. If it moves down, the hinges are not out of adjustment.
Holl
Rich
suburban
thanks guys, got it fixed....
jj91
tn
jay
What did you have to do? Same hinge type but everything appears to be lined up. Shifting the hood latech over some to see would it catch and nothing.
84GMCSierra
Central Arizona
C2500
My 84 Sierra 2500 is doing the same thing. I replaced the original hood with an OEM one and still can't get the back to go down. I even tried raising the cowl panel and that didn't work.
78silverado
