- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
Does it take much to drill holes? Could I just use a harbor freight drill bit set(bulk, cheap ones) and get pilot holes and then use a step bit. I would use atf or power steering or something for lubrication with occasional splashes. I need to drill about 3/8 to 1/2 hole in three spots to mount a trailer jack because my trailer is the frame and bed of a 3/4 ton square, so thick steel. Im using a hole on the frame that exists already for the first bolt, the three others will be drilled.
