Broken85
- Jan 14, 2024
- Cumberland, NJ
- A
- K10
Finally updating the powertrain on my 85 K10 Silverado short bed with a BluePrint turn-key, fuel injected 350. I am going to have to upgrade to a high pressure fuel pump obviously but I wanted to check with the group first before I install this.
My issue is that I have dual fuel tanks so I think the only place I can put this pump would be after the selector valve. Does anyone see an issue with thi?? I have the motor and trans already out so I have plenty of room to install this on the frame and run the lines the right way, but By the time I would figured out this not the best set up, I would likely have the whole Powertrain back in place so all knowledge is welcome. Kit below
EFI Fuel Pump and Plumbing Kit BPP5267 - For Fuel injected engines
Description: BluePrint Engines complete EFI fuel pump and plumbing kit BluePrint Engines complete EFI fuel pump and plumbing kit is your solution when completing the fuel system on your Sniper, Sniper 2, or any EFI engine such as Hemi or LS. We expanded on others fuel pump kits by upgrading to...
blueprintengines.com
