High beams won't switch off?
I always have to mention it since I love them, it's super easy to convert to a floor mounted dimmer switch, if desired.
1984K10
Baytown, Tx
Cristian
5.7 (350CID)
Is there a DIY write up out there I could use? What parts would I need to switch the dimmer to the floor?
I remember posting how to swap it, I'll have to find it. You just get any floor dimmer from any older GM car or truck, your factory dimmer connector on the column plugs right into it after cutting off a useless portion of the connector. The floor is dimpled where the screws go.
1984K10
Baytown, Tx
Cristian
5.7 (350CID)
Ok thank you very much
78silverado
