Here we go
SpeedyDV
San Antonio, Texas
William
It’s sort of like cleaning out the garage. Get everything completely out so you have a clean slate to work with. Instead of all your junk in the driveway, fill up the truck bed with the interior parts. Then clean it up really good with a vacuum and broom, it will gross you out what’s been under the seat - stay calm. Load the new parts back up. My seat foam was in good shape so I installed a saddle blanket cover but with the seat removed, I was able to secure it really well. I ordered the complete plastic trim set. I also had the paint made but i ended up not using the paint because I liked the black color on the trim. New carpet went in easy, you have to trim a little for it to fit. I glued a crappy but overly expensive ($200 with shipping ) dash cover which looks good from a few feet away but the fit and finish is crummy. I wish I would have ponied up ($400-$500) for a complete dash pad replacement. It takes a while to get everything situated but in the end the results will make you want to spend time in the truck. I’m a huge fan of exterior patina and so that will never get redone but having a brand new interior is very cool.
Yeah, I have been pulling everything out as I have time. I have been using a wire wheel and my drill. Oddly enough, the wire wheel was found in the truck while cleaning it out haha. Anyway, for now to save I am just going to redo the dash pad. I am confident I can make it look better than it does now. It will be a slow process, but I will post pics as I begin to make notable progress. Thanks for the info.
Rmangrum
Bentonville AR
It is a journey!
Strip down to metal.
Spray paint where possible.
Replace everything!
It will take time and $ but you will be very happy with as much new as possible.
My78truck
'Ol Holly
Virginia
Becky
C10 Silverado
5.7L
Walked that path like 2 years ago. It is a true labor of love. Take your time, have lots of patience and enjoy the end result. I still cannot believe I totally re-did mine top to bottom all by my little lonesome.
Jeff Lewis
Missouri
Jeff
Time and money.
Bigman240
