Help
Owen454
Canada
Owen
7.4L 454
I've been working on a 89 k3500 I’ve got it to run by squirting gas right down the barrels but I can’t get it to draw fuel from the tank. I’ve changed all the fuses and now believe it could be a fuel pump issue. Any help would be appreciated.
K201979
Winona, missouri
Hippie
350ci
Maybe it just needs a fuel pump. Theyr not too pricey i wouldnt think. Is it mechanical or electric pump? Most recent one i replaced was on an 84 cj7(mechanical) and it wasnt too spendy. Cant remember for sure but i feel like $20-25. Most these squares came with mechanical(lots have been replaced with inline electric), but im not sure on an 89. Someone will chime in. If not , shouldnt b to hard to lookup.
Customblue
Locust Grove, Va
Brandon
Check power to the pump to eliminate broken wires also, make sure to check the ground as well.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Owen454
Canada
Owen
7.4L 454
I’m terrible with electrical how would I go about doing that?
Owen454
Canada
Owen
7.4L 454
It’s an electric pump I just wanted to know if there was anything else I could try bc once I take that tank off I will need a new one.
yevgenievich
Place
Name
Year
Model
Size
There is a fuel pump relay on the firewall passenger side. It has a test lead. If you apply 12v to the test lead, it will directly power the fuel pump
K201979
Winona, missouri
Hippie
350ci
I was afraid it might b in the tank but it sounds like ur gettin the advice u need. Good luck!
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
If the fuel pump is working you can stuff a rag around the filler neck hole and shoot some compressed air in the tank to help it prime up.
1973c10
Don
:welcome:
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Just have to ask... is there gas in the tank?
Mtimi251
