Bruce JOnes
- Aug 3, 2016
- Costa rica
- bruce
- suburban
- cummings 1st gen
Ok I am new to the group so if I do something wrong I am sorry. I need help with a custom job I am working on. First we have an 86 suburban chassie with a 97 suburban body with a first generation cummings 6cyl. I had to jack the suspension way up to get cummings into it. the front axle is tilted down just a slight bit to keep yolk from hitting bottom of oil pan. this in turn throws the steering knuckles off to a tilt. My problem is in my steering, I have lost 3 boxs and 2 times the bolts that attach steering arm to knuckle. I have checked for any type of tension in all of steering linkage but dont have any. Is there any ideas or has anyone else had similar problems? How do I fix this please. I have seen in some other trucks they have put blocks under front springs and between axle to give more lift so yolk will clear. will this work maybe. I am at a loss. Thank you in advance
