Help with Rear Disc Swap
Snoots
Roger
Jimmy Sierra
350 w/203
Then you need to kinda push and pull on the axle shafts while rotating the carrier and the little c clips kinda fall out
Not after an hour and a half.
I agree with you 100%. Tell that to the 'C' clips.
Apparently, there's only a RCH space for them to come out. I did find this . . .
Tomorrow, I attack at 1100!
eskimomann209
Modesto
Marcus
@Arkansas_V8
Come on I’m just teasing man!
It doesn’t bother me.
As soon as that one dies I’m sure I’ll be slapping in a 14bFF
Maybe spray some brake cleaner to remove the gear oil?
Possible that it’s stuck up in there.
The first two took me a long time and a lot of cussing. After that it got easier. Kinda made me begin to question why I struggled in the first place.
Because to actually do the swap. You will be installing and removing those clips a few times to check fit.
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
@Arkansas_V8
Hey, I still have a tooth pick 10 bolt up front. I make it work.
Always gotta make the best of what you have.
Snoots
Roger
Jimmy Sierra
350 w/203
SUCCESS!!!
It took 5 minutes to get the RR out and an hour for the LR.
I got the mounting bracket, bolts, debris shield, parking brake pads and cables for $53. Rotors and calipers were another $50.
They were nice enough to comp me a bottle of water.
Thanks to everyone for their tips and tricks!
C clips can be a real PITA! I should've had a C clamp to hold the axle in. I had to use my foot. I was in positions that would've made a pole dancer jealous.
Now, a shower and the drinking lamp is lit!
idahovette
Weiser Idaho
Perry
K20-K10
Needed somebody with a camera while this was going on!!!
margramby
