Blazin74
- Aug 26, 2018
- Sacramento
- Erik
- Blazer
1974 blazer sbc 350, mostly stock
Ok.... so I replaced my column from a tilt, to a non tilt. (Old one was done)
Rebuilt the non tilt and replaced the old started switch and parking/ neutral switch. Also added electrical grease on the plugs.
Went to connect the battery, and the sucker tries to crack over. With no key in the truck!
So I go right to the ignition switch, to inspect it. A purple wire previously poped out, and I thought I had to it on the right slot. I might not of. Does anyone know where this purple wire goes on the ignition switch?
Update: if I put the wire on the first slot on the left, nothing happens when I click the switch I’ve to start the truck, if I put it on the middle slot, the truck cranks over no matter what position the switch is clicked on
