Help please
ChadwickPNW
Washington
Chadwick
K2500
Replaced electronic choke carb with manual choke Edelbrock 750. Butterfly closes all the way pulled out, opens all the way pushed in. Screws are 1 1/2 out. New Cap, rotor, wires, plugs, fuel filter, valve cover gaskets, fresh non ethanol gas. Triple checked firing order. Set harmonic balancer to 0, rotor points to #1 on TDC on compression stroke. I can get it to fire not idle. Try to keep it running giving gas dies and farts through carb. Tried advancing and retarding. Had lifter noice adjusted, but first time ever doing. STUMPED PLEASE HELP!
Edelbrock
Senior Member
Earth
Grumba
K5 Blazer
Thanks - but no thanks.
ChadwickPNW
