- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
The biggest problem is the small bore of the 305. It greatly limits the valve size you can run and therefore artificially limits the amount of flow you can get from the heads. You end up with the worst of both worlds for making power. It does OK for torque at low RPM, but even that is not great compared to an engine that can get decent heads and valves on it(350, 400, etc..). That's why the 327 is such a great racing motor. Same bore as the 350, but a much shorter stroke. This lets it wind up fast while being able to have all the same airflow potential as a 350 or 400. Airflow is power.Also, if we're talking apples to apples in either 80s or 90s spec, neither of them had great heads (speak in Mustang vs Camaro, not truck) but the 305 FLAT. RAN. OUT. OF. BREATH. at 4500. Carb'd, TPI, TBI, they all were done at 4500, nothing but noise (or windowing the block ) after that. The Mustang would rev to 6-6200 and made power well past 5.
